2001 Toyota Camry Strut Mount Noise
LORRDON
'01 Camry, LE, automatic, 85000 mi., 6 cyl.
Had begun to hear a change in normal road noise. Took car to my regular mechanic ( NOT A DEALER ) who advised that the struts were bad and the tires cupped. $ 1300.00 later the noise was back to normal and the car rode very smooth.
After about a week I noticed that when the steering wheel was turned hard to either side I heard either a rubbing noise , or a clunk, or both from the area of the right front wheel.
Went back to the service guy who road tested the car, put it up on a lift and finally advised that the strut mounts were the cause of the problem, that they " believed " that it was not something very bad or dangerous, that I could have the mounts changed for $ 250.00, or not have the work done but simply get used to the noise, and that - in response to my question - this had nothing to do with the replacement of the struts.
Are they right ?
Sep 30, 2007 at 2:03 PM
BUZZSAW
  • 1,198 POSTS
[quote:6a6659b3b7="lorrdon"]'01 Camry, LE, automatic, 85000 mi., 6 cyl.
Are they right ?[/quote:6a6659b3b7]
sorry to say 1300 for struts and they didnt replace the mounts you got ripped, tires cupped is not a strut prob but an alignment check and tire rotation, if alignment ok your not rotating the tires enough, you have to take off the mounts to replace struts, they could have damaged them putting them back on wrong
Sep 30, 2007 at 9:43 PM
SERVICE WRITER
  • 9,123 POSTS
A symptom of tire cupping can certainly be from weak struts and fatigued springs among other things. A competent and experienced technician would know this. If your steering is impeded than it is a saftey issue that the shop needs to help rectify. It would be fair of them to replace the mounts and re-align the car. You would pay for the parts (since you would have had to anyways) but they should pick up the labor for not recommending them while they were out. If they did recommend the replacement, then you'll have to foot the whole bill.
I can't comment on the price as I don't know what all was done. Was it front, rear, camber kits etc. Other work done on the bill?
Sep 30, 2007 at 10:41 PM
Suggested Repair
Inspect and replace the right-front strut mount if worn or damaged during the recent strut job, then realign the car. If the shop did not recommend mounts while the struts were apart, ask them to cover the labor while you pay for the parts. Also check alignment and tire rotation history, and treat the steering noise as a safety issue until it is verified.
Conversation Summary
The owner of a 2001 Toyota Camry had struts replaced after road noise and cupped tires. About a week later, hard steering produced a rubbing noise or clunk at the right front wheel. The shop blamed the strut mounts, said the issue was not dangerous, offered a $250 repair, and claimed it was unrelated to the strut replacement. One expert said the mounts should have been replaced with the struts and may have been damaged during reinstallation, and attributed cupping more to alignment and tire rotation. Another said weak struts and springs can cause cupping, and that the shop should help replace the mounts and realign if steering is affected, possibly covering labor if the mounts were not recommended earlier.
