My daughter came to me and said her 1995 camry was over heating, So i went and looked at it and the top of the radiator had a 3" split in it. Replaced it and the car ran fine. The next day i replaced the oil pan gasket. i started the vehicle as you would normally after a oil change and then added the rest of the oil. Tried to start it and it would not start. I let it sit for about 2 mins tried again and it fired up. My daughter left and within 40 mins or so she called, said the motor sputtered and then died. We had it towed back to the house and replaced the fuel filter and the fuel pump and stil we are unable to start it. We tested the ignition pack and 2 wires are hot out of 3. could this be our starting issue? [/b]
May 28, 2006 at 3:51 PM
