1996 Toyota Camry Cold Start Stall
DOCCHAVS
i have a Toyota Camry 4 dr sedan 4 cyl. mileage is 140,000.
I have a problem usually in the morning.
whenever i start my car RPM goes down until it engine dies out.
I have to step firmly on gas pedal for a while before(maybe 2-3 mins.) with high RPM before it goes normal.
OR
after i switch the key on, i step on the gas pedal three times then start the engine and wait until the RPM is high enough to maintain the normal idle of my car.....
BUT during the day, once i start the engine on, there are no problems with the RPM(idling)..
hope somebody can enlighten me on this problem.
thanks.....
Mar 1, 2007 at 3:18 AM
DOCCHAVS
my toyota is 1996 model
Mar 1, 2007 at 3:19 AM
  • 75,988 POSTS
[quote:bb977974dc="docchavs"]my toyota is 1996 model[/quote:bb977974dc]
Try checking the CTS/TPS/IACV
CTS: Coolant Temperature Sensor
TPS: Throttle Position Sensor
IACV Idle AirControl Valve
Mar 1, 2007 at 5:40 AM
DOCCHAVS
thank you very much for the response...
but how will i locate all these sensors u are talking about.
Mar 1, 2007 at 8:08 AM
  • 75,988 POSTS
[quote:52cec47f4f="docchavs"]thank you very much for the response...
but how will i locate all these sensors u are talking about.[/quote:52cec47f4f]
You need a manual or take it to a shop and have them scan it/serial data to find out what these sensors are doing
Mar 1, 2007 at 10:43 PM
Suggested Repair
Check the coolant temperature sensor (CTS), throttle position sensor (TPS), and idle air control valve (IACV). Use a service manual to locate them, or have a shop scan serial data to see what the sensors are doing.
Conversation Summary
A 1996 Toyota Camry with about 140,000 miles dies when RPM drops after cold morning starts and needs the gas pedal held for a few minutes, or a few pedal pumps before starting, to hold idle. Once warm during the day, idle is normal. The expert suggested checking the CTS, TPS, and IACV, and using a manual or a shop scan of serial data to locate and evaluate those sensors.
