1999 Toyota Camry P0171 Lean Code
KELLYRO
I have a 1999 4 cyl Camry with 35,000 miles and I'm getting a P0171 OBD code. Can you please tell me what might be causing this. Also does this car have a MAF valve and sensor and if so where is it located. Many Thanks for any help you can provide. Ron
Aug 18, 2007 at 7:01 PM
BRUCE HUNT
  • 3,754 POSTS
Good job by a guy who said his mechanical skills were limited.
Jun 6, 2007 at 1:45 AM
  • 75,988 POSTS
[quote:27181bf1df="kellyro"]I have a 1999 4 cyl Camry with 35,000 miles and I'm getting a P0171 OBD code. Can you please tell me what might be causing this. Also does this car have a MAF valve and sensor and if so where is it located. Many Thanks for any help you can provide. Ron[/quote:27181bf1df]
A PO171 code indicates the engine is running lean. This could mean there is too much air and/or not enough fuel. You can capture this problem by using a scan tool and viewing the short and long fuel trimmings.
A lean fuel mix:
Low fuel pressure,dirty fuel injectors,vacuum leaks
Leaky EGR valve meaning its open when not suppose to,dirty or bad MAF sensor.
The MAF sensor is located at the air cleaner, its in between the throttle body and air cleaner. Also with the IAT sensor
Aug 18, 2007 at 7:58 PM
SIMONK
  • 8 POSTS
you need to have the mass flow sensor cleaned the right way.if you look closely inside the tube you will see two very thin wires and this where the problem is.any small amount of dirt throws this code. dont buy a new one yet.
Aug 20, 2007 at 3:06 PM
LOSTINMARS
  • 222 POSTS
airflow sensors are real common on toyotas. before you start in that direction though i would make sure there are no air leaks after the airflow sensor. if no leak 99% of the time a p0171 on a yota indicates a bad airflow sensor.
Aug 23, 2007 at 7:09 PM
  • 75,988 POSTS
[quote:12876bf3d8="lostinmars"]airflow sensors are real common on toyotas. before you start in that direction though i would make sure there are no air leaks after the airflow sensor. if no leak 99% of the time a p0171 on a yota indicates a bad airflow sensor.[/quote:12876bf3d8]
P0171 indicate the engine is running lean. This means there is too much air and/or not enough fuel.
You can confirm the engine is running lean by looking at Short Term Fuel Trim (STFT) and Long Term Fuel Trim (LTFT). Normally, STFT and LTFT should be plus or minus 8 from zero. If STFT and/or LTFT are more than about +10 or higher, it indicates the engine is running LEAN. Negative numbers (-10 or more) indicates the engine is running RICH.
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Aug 23, 2007 at 10:08 PM
Suggested Repair
Confirm a lean condition with short- and long-term fuel trims. Check for vacuum or intake air leaks after the MAF, then clean the MAF wires with aerosol electronics cleaner only. If the code remains, test fuel pressure, injectors, EGR, and PCV before replacing the MAF.
Conversation Summary
A 1999 4-cylinder Toyota Camry with low mileage has a P0171 code. Experts explain that this indicates a lean mixture from too much air or too little fuel. Possible causes include low fuel pressure, dirty injectors, vacuum leaks, a leaky EGR or PCV valve, and a dirty or faulty MAF sensor. The MAF is between the air cleaner and throttle body. Advice is to rule out post-MAF air leaks and clean the MAF before replacing it.
