1994 Toyota Camry Code 12 No RPM
JMART116
1994 Camry Japan, I4, 5SFE, automatic, 165,000 diagnostic code 12, No RPM signal. Car seems to run fine except every now and then the car will misfire and check engine light will go ON. Car will then apparently correct itself because the check engine light will go OFF. Idles fine except once in a while it will misfire,.. not predictable. It only stalled on me once but started right up,.. hopefully not a sign of future problems. Entire distributor assembly completely replaced 4 years ago, replaced fuel pump & filter 4 years ago. New wires, plugs, rotor last month. Still has original ignitor and ALL original senors. Not sure when to replace sensors. Do you wait to get a fault code for a particular sensor then replace? Has been a great car. My fault code 12 is my problem right now. Any thoughts? Thanks
Aug 2, 2007 at 12:01 PM
  • 31,937 POSTS
Hi there,
Step 1 Check for aprox 0.75 V at each terminal of the distributor harness plug. (distrubitor harness plug)
2. If voltage is not correct, check the wiring for continuity and shorts to earth between Dist & ECU.If no fault found replace ECU.
3. Check the resistance of the distributor pick up coils, if not correct replace distributor.
4. Check the air gap between the signal rotor and the pick up coil, if not correct replace distributor.
This may be a bit to much for you to do, if so have a mechanic do it for you.
Good luck,
Mark (mhpautos)
Aug 2, 2007 at 6:19 PM
Suggested Repair
Check for about 0.75 V at each terminal of the distributor harness plug. If voltage is incorrect, check wiring continuity and shorts to ground between the distributor and ECU, and replace the ECU if no wiring fault is found. Also check pickup-coil resistance and the air gap between the signal rotor and pickup coil; replace the distributor if either is incorrect.
Conversation Summary
A 1994 Toyota Camry with the 5S-FE engine intermittently misfires and sets diagnostic code 12, indicating no RPM signal, while otherwise running and idling normally. Recent ignition parts and an earlier distributor replacement have not resolved it. The expert recommends checking distributor harness voltage, wiring to the ECU, pickup-coil resistance, and signal-rotor air gap, replacing the ECU or distributor only if those checks fail.
