1994 Toyota Camry code 13
78,000 MILES • 4 CYL • FWD • AUTOMATIC
42HOTROD12
  • 7 POSTS
has code 13 replaced distributor checked wiring and connectors to ecm
is a bad ecm common on this car?
Oct 9, 2009 at 9:10 AM
  • 75,988 POSTS
DTC 13 G, NE Signal Circuit No. 2.
Distributor has been replaced wiring has no open or short circuit-last place is the ECM either you swap or replace it-and see what happens
Oct 9, 2009 at 10:17 AM
