1987 toyota camry 104,000 miles, 4cyl, auto, wagon, without hooking up a obd1 reader is there a way to retieve check engine codes
Jul 14, 2007 at 9:24 AM
Locate the diagnostic connector on the right-side fender, jump TE1 (which may be labeled TEm) to E1, and count the two-digit flashes on the check engine light. Code 22 was retrieved and associated with the water temperature sensor, but no further expert diagnosis was given.
The owner of a 1987 Toyota Camry asked how to retrieve check engine codes without an OBD1 reader. The expert advised jumping TE1 to E1 at the right-fender diagnostic connector and reading the two-digit flashes on the dash light. After locating E1 and a terminal labeled TEm, the owner retrieved code 22 and suggested it may indicate the water temperature sensor.
