how to replace 92 TOYOTA CAMRY REAR DOOR HANDLE RH
Feb 11, 2007 at 6:35 AM
Consult a Haynes manual for the 1992 Camry. Remove the interior door panel to access the outside rear door handle, and check for a loose bolt. Cracked plastic housings generally must be replaced; epoxy is only a possible temporary repair if the plastic type is known.
The owner asked how to replace the right rear outside door handle on a 1992 Toyota Camry. The expert recommended a Haynes manual, removing the interior panel for access, checking for a loose bolt, and replacing cracked plastic housings rather than relying on epoxy unless the plastic type is known.
