1995 Toyota Camry No Overdrive When Cold
WILLCVL
Make: Toyota
Model: Camry
Year: 1995
Milage: 120K
Engine size: 2.2 liter
The auto transmission won't shift into overdrive when cold. Is this normal? Someone told me the Transmission Fluid Temperature sensor does not allow overdrive when the transmission fluid is too cold. Why?
Jun 10, 2007 at 1:38 AM
KIN CHAN
  • 453 POSTS
EASY!~!!!!!!!!...... 2 sensors u wanna chk out ....the coolant and trans temp sensors ..1 for power train computer and 1 for transmission computer....the reason behind this strategy is emission....if ur engine rev low at overdrive b4 warm up..it'll emission more hydrocarbon emission..is the EPA man...but typical toyota if everything working normal ...it should take about a few minute at ambient temp above 40 deg F to kicks in O/D ...unless ur temp sensors are outta range...which is the job for ur mechanic to find out ..
good luck man
Jun 10, 2007 at 1:51 AM
  • 75,988 POSTS
[quote:3406e5ea99="willcvl"]Make: Toyota
Model: Camry
Year: 1995
Milage: 120K
The auto transmission won't shift into overdrive when cold. Is this normal? Someone told me the Transmission Fluid Temperature sensor does not allow overdrive when the transmission fluid is too cold. Why?[/quote:3406e5ea99]
I will try the coolant temperature sensor. It prevents overdive and lock-up under predetermined temperature 122deg-162deg
The computer monitors coolant temperature and sends the signal to the OD1 ECT ECU. The ECU will provide OD and Lock-up when the temperature has reach its calibration point.
Could be the throttle position and vehicle speed sensors,these sensors controls throttle and governor pressure.
Jun 10, 2007 at 11:09 AM
Suggested Repair
Check the coolant temperature sensor and transmission temperature sensor. Overdrive and lock-up are inhibited until coolant reaches the calibrated range, about 122-162°F, which can take a few minutes above about 40°F. If the delay continues after warm-up, also check the throttle position and vehicle speed sensors.
Conversation Summary
A 1995 Toyota Camry with a 2.2L engine and 120,000 miles will not shift into overdrive when cold. Replies say this can be normal until the transmission warms, mainly for emissions control, and that the powertrain computer uses coolant and transmission temperature signals to enable overdrive and lock-up. The expert recommends checking the coolant temperature sensor first, noting the inhibit range of about 122-162°F, and also considering the throttle position and vehicle speed sensors.
