1999 Toyota Camry Check Engine Light
BOBK544
I replaced the front Oxygen Sensor on my 1999 Toyota Camry and the "Engine Check Light" is still on even after pulling the battery connections!
Do i have to do anything special with the Camry to turn that light off?
I'm hoping that the original problem has been fixed and that the light only needs to be reset?
Thanks for any insights!
BobK
Fairfax Va
Sep 9, 2006 at 5:30 AM
  • 75,988 POSTS
Try removing the EFI fuse for 10sec or more, if it comes back. Jump T1 to E! on the diagnostic connector, then start counting the flash of the lite.
Sep 12, 2006 at 9:27 PM
Suggested Repair
Remove the EFI fuse for at least 10 seconds to reset the check engine light. If it returns, jump T1 to E1 on the diagnostic connector and count the light flashes to read the code.
Conversation Summary
The owner of a 1999 Toyota Camry replaced the front oxygen sensor and disconnected the battery, but the check engine light remained on. The expert advised removing the EFI fuse for 10 seconds or more and, if the light returns, jumping the diagnostic connector terminals and counting the flashes.
