Cooling Fans
DIVA31
I have a 1999 Toyota Camry. When I drive the vehicle to the desired temperature in which the fans are suppose to come on they don't. When I turn the air conditioner on I see that they do come on. What could be causing this problem?
May 29, 2007 at 8:51 AM
  • 75,988 POSTS
[quote:ef9f98fb6f="diva31"]I have a 1999 Toyota Camry. When I drive the vehicle to the desired temperature in which the fans are suppose to come on they don't. When I turn the air conditioner on I see that they do come on. What could be causing this problem?[/quote:ef9f98fb6f]
Camry can be a very tricky to deal with, it has about 4 fan relays-start with the coolant temperature sensor/thermal switch-fuses.Could also be the thermostat.and also the computer not activating the relay.
May 29, 2007 at 4:09 PM
