1993 Toyota Camry Accidentally poured gas into the radiator
PEACHES88
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 240,000 MILES
My car began to run hot and I decided to put antifreeze in my radiator. Instead I accidentally poured gasoline into the radiator because gas was in the antifreeze bottle. My car was running and I automatically assumed since it was kind of smoking from where you insert the antifreeze at, that the gasoline had ran through my motor probably. But I poured gas into my radiator while the car was running. What can I do?
Wednesday, December 19th, 2007 AT 10:34 PM
  • 31,937 POSTS
Hi there,
Flush the cooling system and re fill with coolant, you still may see a little film on the coolant but that wont be a problem.
Mark (mhpautos)
Wednesday, December 19th, 2007 AT 11:27 PM
