1996 Toyota Camry RADIATER
SUEBELL1953
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • 211,000 MILES
WHAT CAUSES THE RADITER TO SOUND LIKE IT IS BOILING OVER WHEN I TURN MY CAR OFF? IT HAS WATER AND COOLIENT IN THE CAR. OIL IS FINE, WATER IS FINE.
Tuesday, August 11th, 2009 AT 7:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Is your temperature gauge remaining in the normal operating range?
Tuesday, August 11th, 2009 AT 12:39 PM
SUEBELL1953
  • 5 POSTS
YES, THERE IS NO CHANGE IN THE TEMPERTAER GAUGE.
Tuesday, August 11th, 2009 AT 1:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
How long has it been since you have had your cooling system flushed?
Tuesday, August 11th, 2009 AT 2:12 PM
SUEBELL1953
  • 5 POSTS
LAST YEAR I HAD A NEW RADITOR PUT IN AND IT WAS CLEANED THEN.
Tuesday, August 11th, 2009 AT 2:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If water is boiling in radiator then it is overheating. Since gauge is reading normal I would suspect faulty coolant temp. Sensor.
Tuesday, August 11th, 2009 AT 8:06 PM
