Hi I have a Toyota Camary 1992 aprox. 190,000 miles and a V6 manual car. I have been having problems with the clutch. When i push down on the clutch it stays on the floor, I can bring it back up but will not shift gears. It also is very loose. When I opened the hood to take a look at it and pushed on the clutch you can hear and see fluid coming out. So I am guessing that I have a Hydraulic clutch and that it has a leak. Do you think that I just need a new line/pump for the clutch or do you think it's going to take way more than that?
Nov 27, 2007 at 10:42 AM
