1999 Toyota Camry Wrong ATF Type
ALIROSE33
My friend has a 1999 Toyota Camry.I just noticed that she put "Type F" transmission fluid in the car,when it calls for "Dextron III". She seems to think that it'll be fine.I disagree.Might this cause damage to her transmission,and if so, what should she do to avoid damage?The car was very low on fluid and she added 1 quart of type F.
Dec 28, 2006 at 1:40 PM
SERVICE WRITER
  • 9,123 POSTS
Always put in the correct fluid or you may create a problem. Today's cars are engineered for certain goals, and the fluid properties can be detrimental.
Low fluid however will burn out the clutches and she may have already caused damage.
I'd flush it and get new fluid in it, it's good maintenance anyway.
Here is the fluid it should take.
Fluid Types
A/T Fluid
Type .................... D-II, DEXRON II or DEXRON III
Capacities
Automatic Transaxle Fluid
Drain and Refill .................... up to 2.5 liters (2.6 US qts)
Fluid Type .................... ATF D-II or Dexron-III - Dexron II (r)
Differential Fluid
Capacity .................... 1.6 liters (1.7 US qts.)
Total dry fill combined .................... 7.2L (7.6 qts.)
Dec 28, 2006 at 10:19 PM
Suggested Repair
Flush the transmission and refill with the specified ATF (D-II, Dexron II, or Dexron III). Do not continue using Type F. Low fluid may already have damaged the clutches.
Conversation Summary
A 1999 Toyota Camry that calls for Dexron III was low on fluid and received one quart of Type F ATF. The expert said the wrong fluid can cause problems, low fluid can burn the clutches, and the transmission should be flushed and refilled with the correct fluid.
