1992 Toyota Camry Reverse Clutch Noise
1992 TOYOTA
i recently bought a tototo camry 1992 model manual.whenever i put the gear in the reverse and release the clutch some squeezing sound is coming .there is no problem with the forward gears and also the clutch seems to be a little deep too ,means i have to press the clutch a long way deep.does the car need clutch replacement and around how much will it cost to repair the car?
Sep 29, 2007 at 6:09 PM
Hi there,
The noise may just be the pedal box pivot bush, lube with a little spray on lube should fix that, as for the clutch it self check for fluid loss and repair as required with the engine on and in gear clutch depressed, drive should begin to engage with the pedal just off the floor, if drive is not felt untill the pedal is well up the clutch is probably worn. As these are a hydrostatic clutch (no adjustment) you may be due for a clutch O/haul.
Mark (mhpautos)
Mark (mhpautos)
Sep 30, 2007 at 12:46 PM
Suggested Repair
Lubricate the clutch pedal box pivot bush with a spray lubricant. Check for hydraulic fluid loss and repair any leaks. With the engine running and a gear selected, drive should begin to engage just off the floor; if engagement is high in the pedal travel, the non-adjustable hydraulic clutch is likely worn and may need an overhaul.
Conversation Summary
The owner of a 1992 Toyota Camry manual reports a squeezing noise when releasing the clutch in reverse and a clutch pedal that must be pressed very far. Forward gears are fine. The expert says the noise may be a dry pedal-box pivot bush that needs lubrication, advises checking for fluid loss, and notes that late engagement on this non-adjustable hydraulic clutch indicates wear and a possible clutch overhaul.
