Brake problem
YEEKILLA
1994 Toyota Camry LE
206588
When I replace new brake pad after to it i test see how they go but brake wont work to stop but it drive keep moving never stop it?
Oct 31, 2007 at 10:39 AM
BLACKOP555
  • 10,386 POSTS
woah man slow down, can you retype that for us. explain more in detail so i can read it :P
Oct 31, 2007 at 11:58 AM
YEEKILLA
1994 Toyota Camry LE automatic
When I replace new brake pad everything look fine and put all back together in normal way. But I test it brake didnt hit brake pad to stop the rotor to stop the car, it just keep moving. So I shift parking right way because brake wont active to stop it.
GOT ANY CLUE :?
Did I miss anything part or no :?
Dont know how to donate?
Nov 1, 2007 at 2:09 AM
LOSTINMARS
  • 222 POSTS
you probably twisted the brake hose and now its got a kink in it.
Nov 3, 2007 at 6:29 PM
BLACKOP555
  • 10,386 POSTS
does your brake pedal go right to the floor with ease? if so you may need to bleed the brake system!
Nov 4, 2007 at 12:48 AM
