1991 Toyota Camry Poor Acceleration
DANIELOVE
hey i have a 1991 toyota camry. and just last night it made a clunking noise and it was because of the lack of motor oil. so i immediately bought some and filled it to the full line. i went to my car today for my daily breakfast and it has a tough time accelerating. the rpm's will go up but not much else happens. i've checked the transmission fluid and it all comes out fine so im betting it has to do with the engine oil problem. i don't know what this could be.
thanks
Sep 30, 2007 at 8:43 AM
FISHERMAN
  • 937 POSTS
[quote:c94142eb9c="danielove"]hey i have a 1991 toyota camry. and just last night it made a clunking noise and it was because of the lack of motor oil. so i immediately bought some and filled it to the full line. i went to my car today for my daily breakfast and it has a tough time accelerating. the rpm's will go up but not much else happens. i've checked the transmission fluid and it all comes out fine so im betting it has to do with the engine oil problem. i don't know what this could be.
thanks[/quote:c94142eb9c]
How many miles on your vehicle?
how low was the engine oil?
any maintenance records?
Sep 30, 2007 at 9:06 AM
DANIELOVE
it has 170,000 miles and the oil was empty. but no i don't have any maintenance records. ive had the car for almost a year
Sep 30, 2007 at 9:42 AM
FISHERMAN
  • 937 POSTS
[quote:1173711100="danielove"]it has 170,000 miles and the oil was empty. but no i don't have any maintenance records. ive had the car for almost a year[/quote:1173711100]
Well probably the noise you hear wasn`t the engine..
could be the tranny...
at least you find out that your engine was running with low oil..
do you know the history on the transmission?
check engine light off?
Sep 30, 2007 at 10:13 AM
DANIELOVE
no im almost positive its not the tranny. i replaced it not even half a year ago.
but my stepdad said he thinks that when i drove it that short distance without the motor oil, the engine got really hot and it might have warped something in the engine.
but no, the check engine light isnt on
Sep 30, 2007 at 10:55 AM
FISHERMAN
  • 937 POSTS
[quote:d388da3274="danielove"]no im almost positive its not the tranny. i replaced it not even half a year ago.
but no, the check engine light isnt on[/quote:d388da3274]
OK but you said that the engine rev go up good..
well but probably with no power..
any weird noise?
its idling smoth?
you have to check the compression on the cylinders..
and we start from there..
Sep 30, 2007 at 12:49 PM
KALIKUTES
[quote:b9ef64a193="danielove"]hey i have a 1991 toyota camry. and just last night it made a clunking noise and it was because of the lack of motor oil. so i immediately bought some and filled it to the full line. i went to my car today for my daily breakfast and it has a tough time accelerating. the rpm's will go up but not much else happens. i've checked the transmission fluid and it all comes out fine so im betting it has to do with the engine oil problem. i don't know what this could be.
thanks[/quote:b9ef64a193]
I HAD THE EXACT SAME PROBLEM. IT TURNED OUT TO BE MY BEARINGS THAT NEEDED TO BE REPLACED FROM SCRAPING DUE TO NO MOTOR OIL. LUCKILY I FOUND SOMEONE WHO WOULD DO JUST THAT FOR ME. BECAUSE EVERYONE I CALLED JUST KEPT TELLING ME TO GET A NEW MOTOR.
Nov 19, 2007 at 12:29 AM
Suggested Repair
Perform a cylinder compression test to check for engine damage after the engine ran with no oil. Use those results before assuming a transmission problem.
Conversation Summary
The owner of a 1991 Toyota Camry with 170,000 miles heard a clunk after driving with no engine oil, refilled the oil, and then found the engine revved with little acceleration. Transmission fluid looked fine, the transmission had been replaced recently, and the check engine light was off. The expert recommended starting with a cylinder compression test. Another owner reported similar oil-starvation damage to the bearings.
