1985 Toyota Camry Stalls on Acceleration
JBUCHBINDER
I have a 1985 Toyota Camry Le, approx. 73,000 miles, automatic, 4 cyl. About a month ago, every so often the engine would be hard to start in the mornings. I took it to a mechanic and they said the fuel pressure was low. I put in a fuel additive to clean out the gas tank, and I haven't had this starting problem since. However, a new problem developed shortly after this. After I warm my car up in the morning, back out of the driveway, change from reverse to drive and then accelerate, the engine will stumble, and sometimes die. When I restart, the engine sometimes stumbles again, then it works fine. Other times, when I'm at a stoplight, I will have the same problem - when I go to accelerate, the engine will stumble, then die, and I have to restart. I've also noticed I have a low, rough/uneven idle. I also hear a clacking sound when I accelerate at freeway speeds or uphill. A couple weeks ago, I had a Toyota specialist do an ignition/fuel injection system diagnostic, and they said my fuel pressure was good, but I may have a bad pickup coil/igniter/ignition coil. I've replaced the alternator, drive belt, spark plugs, and air filter. I'd appreciate any light you could shed on this problem. Thanks.
Oct 8, 2007 at 7:03 AM
BUZZSAW
  • 1,198 POSTS
[quote:543ba40a49="jbuchbinder"]I have a 1985 Toyota Camry Le, approx. 73,000 miles, automatic, 4 cyl. About a month ago, every so often the engine would be hard to start in the mornings. I took it to a mechanic and they said the fuel pressure was low. I put in a fuel additive to clean out the gas tank, and I haven't had this starting problem since. However, a new problem developed shortly after this. After I warm my car up in the morning, back out of the driveway, change from reverse to drive and then accelerate, the engine will stumble, and sometimes die. When I restart, the engine sometimes stumbles again, then it works fine. Other times, when I'm at a stoplight, I will have the same problem - when I go to accelerate, the engine will stumble, then die, and I have to restart. I've also noticed I have a low, rough/uneven idle. I also hear a clacking sound when I accelerate at freeway speeds or uphill. A couple weeks ago, I had a Toyota specialist do an ignition/fuel injection system diagnostic, and they said my fuel pressure was good, but I may have a bad pickup coil/igniter/ignition coil. I've replaced the alternator, drive belt, spark plugs, and air filter. I'd appreciate any light you could shed on this problem. Thanks.[/quote:543ba40a49]
what about t-belt and fuel filter, if coil has burn marks then wires need replacing too, cold start injector may need replacing
Oct 10, 2007 at 7:08 AM
Suggested Repair
Check the timing belt and fuel filter. Inspect the ignition coil for burn marks and replace the spark plug wires if marks are present. The cold start injector may also need replacement.
Conversation Summary
The owner of a 1985 Toyota Camry with about 73,000 miles reports stumbling or stalling when accelerating from a stop after warmup, a low rough idle, and clacking under freeway or uphill acceleration. Earlier hard starting improved after a fuel additive, and a specialist found good fuel pressure but suspected the pickup coil, igniter, or ignition coil. The alternator, drive belt, spark plugs, and air filter were already replaced. The expert suggested checking the timing belt and fuel filter, replacing the wires if the coil has burn marks, and possibly replacing the cold start injector.
