Engine starts up and idles fine when it's cold. As soon as the engine warms up, after about 15 or 20 minutes, it sputters and dies. When this happens there is no spark at the plugs. It will spark once and then no spark. Once it cools down (15 minutes or so later) the it cranks and starts up just fine again. This is driving me crazy!
Also, I found a little oil in the distributor cap when this initially happened. The neutral safety switch acts up sometimes too.
Have already replaced:
wires
cap
rotor button
ignition coil
ignitor
air filter
oil pressure switch
ANY help or ideas would be great! Thanks
SPONSORED LINKS
Wednesday, April 25th, 2007 AT 7:38 AM
