ENGINE STALLS
DHATZIPA
The Camry is SE, 8th digit in VIN is K.
Note dealer scanned the vehicle several times, no bad codes came up!
So, what could be the issue?
Thursday, June 18th, 2020 AT 10:08 AM (Merged)
IMPALASS
  • 3,112 POSTS
Hello
There are several things that can cause these symptoms. There are a couple of sensors, MAF, Intake Air temperature and Coolant. A defective engine coolant temperature sensor can cause most of the symptoms you are having. You would need a digital volt meter to check. Do you have that?
COMPU_STUD69
  • 2002 TOYOTA CAMRY
  • 6 CYL
  • 96,000 MILES
My car starts fine as long as you have your foot on the gas. It wont idle at all either unless your foot is on the gas. Then you can drive but take your foot off the gas and dies. Any help would be great!
CHASESHAW
Did you ever get an answer to this? Am having the same problems and have adjusted the throttler, and replaced the whole IAC control assembly and still having the same problem on mine.
  • 31,937 POSTS
Hi there,
do the tune up first and check the ECU for fault codes, you wont always get a light on with all codes, this may be a faulty TPI sensor, start here.
Mark (mhpautos)
IMPALASS
  • 3,112 POSTS
Hello Chaseshaw
No I have not received back any info yet
COMPU_STUD69
I have checked the codes and there are no codes.I was reading and I was seeing that it may be the alternator, the spark plugs, the fuel pump etc. But it drives fine on the freeway or anywhere else as long as your foot is on the gas. No hessitation when you accelerate or anything. Any more help would be great. Thank you!
  • 31,937 POSTS
The alternator is the power supplier for the fuel pump, this is so, so if the car is involved in an accident and the ignition is on the pump wont keep running, so you may be on the right track, a faulty alternator may be causing this problem, get this checked.
Mark (mhpautos)
ALI
  • 2002 TOYOTA CAMRY
  • 6 CYL
Guys, my car does not always start from first attempt, it turns over, but does not start. It Sometimes start from first time, and other times start from the second or third attempt. I have cleaned the throttle and ensured that the plugs are fine and the battery is fine too. But no luck
Some told me that the ECM needs to be changed. Did anyone run into
Check the fuel pressure to rule out a clogged fuel filter and a weak fuel pump-could also be losing fuel pressure due to injectors and fuel pressure regulator leaking and a defective coolant temperature sensor-
HENMOE88
  • 2002 TOYOTA CAMRY
  • V6
  • 181,000 MILES
I have a 2002 Toyota Camry LE V6. One night I was driving it and the car shut off on me. At first I thought it was the alternator, but I got it tested and it was fine. So then I thought it was the battery and I bought a new battery. That seemed to work at first, but then when I started to drive it the car shut off on me again, but this time when I started it up it would come on, but it couldn't stay on unless I pushed the gas pedal and if I went idle the car would turn off. So basically, the car can start up, but it can't stay idle without me pushing the gas pedal.
HMAC300
  • 48,601 POSTS
Clean the throttle plate on both sides with choke cleaner and iac hole. Then check fuel pressure with a gauge autoparts rent them.
BAMAJ
  • 2002 TOYOTA CAMRY
  • 24,100 MILES
Car sometimes stumbles like its starving for fuel, now it just dies going down the road, dash lights come on like it died. Put it in nuetral and it revs back to idle. Cleaned maf sensor to no avail. Throws code 1305 but does not stumble like its electrical misfire. Wondered if maf problems could throw this error code.
  • 52,797 POSTS
A Direct Ignition System (DIS) has been adopted. The DIS improves the ignition timing accuracy, reduces the high-voltage loss, and enhances overall reliability of the ignition system by eliminating the distributor.
The DIS is a 1-cylinder ignition system which ignites one cylinder with one ignition coil. In the 1-cylinder ignition system, the spark plug is connected to the end of the secondary winding. High voltage generated in the secondary winding is applied directly to the spark plug. The spark of the spark plug passes through from the center electrode to the ground electrode.
The ECM determines ignition timing and outputs the ignition signals (IGT) of each cylinder. Based on IGT signals, the power transistors cut off the current to the primary coil in the ignition coil. At the same time, the igniter also sends an ignition confirmation signal (IGF) as a fail-safe measurement to the ECM.
INSPECTION PROCEDURE
HINT:
If DTC P1300/14 is displayed, check No.1 ignition coil with igniter circuit.
If DTC P1305/15 is displayed, check No.2 ignition coil with igniter circuit.
If DTC P1310/14 is displayed, check No.3 ignition coil with igniter circuit.
If DTC P1315/15 is displayed, check No.4 ignition coil with igniter circuit.
Read freeze frame data using the hand-held tester or OBD II scan tool, as freeze frame data records the engine conditions when the malfunction is detected. When troubleshooting, it is useful for determining whether the vehicle was running or stopped, the engine was warmed up or not, the air-fuel ratio was lean or rich, etc. At the time of the malfunction.
JAHBLADES
  • 2002 TOYOTA CAMRY
  • 100,000 MILES
I would start the vehicle but is would not stay running
KHLOW2008
  • 41,814 POSTS
Any dash indicator lights showing?
Does feathering gas pedal keep it running?
Any repairs prior to this occurring?
JAHBLADES
No dash light on, once you hold the gas pedal it will run, the minute you take your foor off the pedal it shut off
KHLOW2008
  • 41,814 POSTS
Idling speed is too low.
Check for vacuum leaks and have the throttle body and IAC clened.
