2000 Toyota Camry Vibration
DAVID H ALLEN
  • 2000 TOYOTA CAMRY
Tires and Wheels problem
2000 Toyota Camry 4 cyl Two Wheel Drive Automatic 155K miles
Ever since we have had the car there has been a vibration in the front end. It did this even when we test drove the car. We had them to put a new set of tires on and the vibration went away for awhile. After about 2500 to 3000 miles it started vibrating again. Took the car in had the tires checked to see if one had lost a weight and was out of balance. They were fine. Had the tires rotated and the vibration stop again for about 2500 or 30000 miles and it started all over again. We have had everything check out that could be, and still a vibration. Any clue as what it could be? We have a "92" camry and never had any problems. I did notice the 92 has 14 inch wheels and the 2000 has 15 inch.
Wednesday, September 15th, 2010 AT 6:53 PM
MMPRINCE4000
  • 8,548 POSTS
If new tires solve the problem, then it comes back, it is a worn suspension component.
Either camber or toe is out, possible wheel bearing.
An alignment shop should be able to find problem.
Thursday, September 16th, 2010 AT 9:17 AM
