2000 Toyota Camry noise from front suspension
30OUT
2000 Toyota Camry 4 cyl Front Wheel Drive Automatic
what is the possible cause of a knocking noise coming from underneath the car near the front wheel? This is mostly at slow speeds.
Jan 15, 2010 at 1:19 AM
BLACKOP555
  • 10,386 POSTS
usually is a bad strut or a issue with worn stabilizer bar bushings. since it dont make noise in breaking i doubt it is the caliper
Dec 11, 2020 at 4:49 AM
DOLEMITE44149
  • 17 POSTS
I also had noise on my camry when at a stop light/very low speeds. Shifting into neutral stopped the rattling.
At first I thought it was the engine mounts. Turns out it was the heat shield by the converter.
I yanked that baby off and now it sounds great. Although it gets really warm in the passenger seat now!
Haha, just kidding (about the heat)
Good luck!
