1999 Toyota Camry Memory Steer Pull
HAYNAY
We have a 1999 Camry 4 cyl with 185000 miles manual transmission. We have had the struts replaced twice on the front in the last two to three years due to a clunking noise or rattling sound when going over bumps, dips in the road, etc. Just had it to the dealer because of continued noise and they suggested changing the strut mounts. I changed the mounts and now the car pulls to the right or left. If you make a hard turn to the left, when you straighten out it continues to pull to the left and vise versa on the right. I just had new tires put on a couple of days before I changed the strut mounts. I had the car aligned after the pulling problem started and it was not out much and is still pulling. I have to hold the steering wheel tight to keep it from roaming off the road in either direction. I also noticed that there seemed to be a "catch" in the steering before I did any of the mount work. I don't see where anything I did with replacing the strut mounts could have caused the steering problem? I am thinking rack and pinion or possible CV joints? Any thoughts?
Feb 6, 2007 at 4:22 AM
SERVICE WRITER
  • 9,123 POSTS
Clarification:
Hold tight to the steering wheel?
Do you have to over compensate for the movement, or are you just holding it straight with no compensation?
Dec 11, 2020 at 4:49 AM
HAYNAY
What I mean by that is you have to hold it straight or it will vere off to the right or left depending on the last tight turn that was made. It wants to steer in its own direction.
SERVICE WRITER
  • 9,123 POSTS
Definitly not cv joints. What you're describing is called memory steer if I understand you correctly. Something is binding and not allowing the steering components to come back after a turn.
If the dealer is your chioice of repair facilities, you need to talk to the service manager and have him take it for a ride with you, since this problem wasn't there before and they suggested it, they should hold a little repsonsibility on this. The mounts should have had the strut bearings with it when they changed it, but sounds like they may have reused the old ones and disturbed they way they were.
Suggested Repair
Treat the pull as memory steer from a binding steering component that does not return after a turn. Have the dealer service manager road-test the car, since the pull began after the recommended strut-mount work. Confirm the strut bearings were replaced with the mounts rather than reused.
Conversation Summary
A 1999 Toyota Camry with repeated front clunking had strut mounts replaced after the dealer recommended it. New tires and an alignment did not stop a pull that follows the last hard turn, and the wheel must be held to keep the car straight. The expert ruled out CV joints, identified memory steer from binding parts, and said old strut bearings may have been reused and disturbed.
