1993 Toyota Camry Severe front end shaking
1993 TOYOTA CAMRY
155,125 MILES • 4 CYL • 2WD • AUTOMATIC
GREG47
When I accelerate, especially on the highway, the whole front end shakes. Someone suggested it may be front right axel bearing costing me $1,000 or so. I'm hoping the problem is totally worn out struts or major front end. Thanks, Greg47
Jun 16, 2010 at 11:51 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will have to get the suspension checked out, struts, ball joints, sway bar, and steering links and rack, check wheel bearings & drive shafts, also have the sub frame bolts backed odd and re torqued, this is an over often forgotten service item that can help with front end vibration, start here.
mark (mhpautos)
Jun 17, 2010 at 12:46 AM
