2000 Toyota Camry
NBRYSON
  • 2000 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 13,000 MILES
Timing belt chain & water pump were replaced and not enough coolant put back in the vehicle causing to overheat after driving about 10 minutes. Vehicle was pulled over and coolant added. Is it possible that an oil pump gasket leak could be caused by the overheating or could have been nicked while someone was working on the timing belt chain or was the leak most likely developed over time due to cracking with age?
Wednesday, October 22nd, 2008 AT 8:36 AM
KHLOW2008
  • 41,814 POSTS
Hi NBryson,
Oil pump gaskets hardens ovet time and if any work was done nearby, the vibration could have caused it to leak.
Overheating is also possible so does careless workmanship. It is a matter of interpretation.
Thursday, August 1st, 2019 AT 6:29 PM
