2000 Toyota Camry timing belt
HISTORLEE
  • 2000 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 230,000 MILES
Can you check to see if belt has been replaced recently.
How hard is it to replace right front mirror
Saturday, April 25th, 2009 AT 9:03 PM
DAVE H
  • 13,384 POSTS
Most repair shops will add a sticker stating @ the last mileage and date the belt was changed ..If in doubt .. replace, to be on the safe side !!
Removal & Installation
Remove mirror inner trim panel on inside of the door. Mirror inner trim panel may include speaker. If necessary, disconnect speaker harness connector. Disconnect power mirror motor harness connector. Support outside mirror assembly while removing mirror retaining bolts/nuts on inside of the door. To install, reverse removal procedure.
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_569.png
Sunday, April 26th, 2009 AT 6:12 AM
