2000 Toyota Camry Dome Light Out
FATBOYPIZZAEATER
I have a 2000 v6 LE camry with 65K milegage on it. My car's dome light is not glowing and I checked the bulb and it is good. I was trying to check the fuse (one under the change holder and one under the hood) and could not find any fuse labeled by "dome". How could I find and replace it. All other interiors (Radio, dashboard) are working fine.
Thanks and I appreciate your time.
May 21, 2007 at 5:06 AM
  • 55,851 POSTS
That fuse is in the under hood fuse box,fuse #14 = 7.5AMP here is a guide to help you test the fuse.
Here are the fuse panel locations and identification (below) you should keep this page in your favorites for future reference. It shows the relays as well
Check out the diagrams (Below)
Cheers, Ken
Feb 13, 2018 at 4:30 AM
MICHAEL SAPP
Thank you!
Suggested Repair
Check under-hood fuse #14 (7.5 amp) for the dome light and test or replace it if blown. Use the fuse panel diagram to confirm the location.
Conversation Summary
The owner of a 2000 Toyota Camry said the dome light does not glow even though the bulb is good and other interior electronics work. They could not find a fuse labeled dome. The expert identified under-hood fuse #14 (7.5 amp) and directed them to fuse-testing guidance and fuse panel diagrams.
