1999 Toyota Camry struts
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
4092KEITH
I was told by the corner mechanic that the noise that I hear when driving the car was do to the old struts needed to be replaced. It made a rattle sound which was definately coming from the front section of the car. So i had them replaced in the front, Get the car home it still rattles, car seems to drive better but I still get this rattle sound. I even check to see if the mechanic left a tool inside the front fender. can not find the where it's coming from.
Did you ever hear of anything like this.
Dec 11, 2008 at 7:29 AM
  • 31,937 POSTS
Hi there,
If this is the same noise that you had before the struts were replaced i would be right back to the mechanic and getting them to check it out, it could be a suspension problem still unresolved.
Mark (mhpautos)
Dec 11, 2008 at 7:51 AM
