1998 Toyota Camry My gear selects but those not work
ROBSIMON011
  • 1998 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 120,000 MILES
Tuesday, June 29th, 2010 AT 1:10 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will have to first check that the oil level is ok and that the oil is not burnt, also run a scan for any unresolved fault codes, failing that, it will have to be checked first hand by a trans tech, also ensure that the selector has not come loose at the trans and that it is actually selecting gears at the box. Tart here.
Mark (mhpautos)
Tuesday, June 29th, 2010 AT 11:02 PM
