1998 Toyota Camry Car runs hot, unless A/C is turned on.
KRISSEN
  • 1998 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 123,023 MILES
Hi, recently I noticed the thermostat gauge show the car running hot, not overheating, or in the "red area" near the H. But if I have the a/c off, it starts climbing higher, and if I turn the A/C back on, the temp is right back to normal. I took it to a mechanic, they checked the radiator fluid, it was fine. They also made sure the cooling fans were turning on at appropriate times, and they were working fine. They couldn't figure out what was causing the high temp to go down when the a/c is turned on. I'm thinking maybe there's a ground wire or relay issue?
Wednesday, June 9th, 2010 AT 8:54 PM
  • 31,937 POSTS
Hi there, with the A/C on the second cooling fan is cutting in, this is increasing the air flow through the radiator, check for a part blocked radiator, faulty thermostat, faulty pressure cap, start here, '
'mark (mhpautos)
Wednesday, June 9th, 2010 AT 9:21 PM
