1997 Toyota Camry timing belt change
PASTOR AL
  • 1997 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 211,000 MILES
We just had the timing belt replaced on our 1997 toyota Camry and now experience a shaking at tstart up and at stop signs. It seems to correct itself after a little while. What's going on? We also replaced the rear struts.
Friday, November 5th, 2010 AT 1:28 PM
KHLOW2008
  • 41,814 POSTS
Hi pastor Al,
Check the ignition timing, if it is out by many degrees, the timing belt could have been installed incorrectly.
If ignition timing is correct, check the spark plugs and idling speed. Throttle body body and IAC might require some cleaning.
Saturday, November 6th, 2010 AT 12:39 PM
