1997 Toyota Camry oil pan leaking
1997 TOYOTA CAMRY
202,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLB253
Hello, my oil pan is leaking, I hit a dip a couple of weeks ago. Is this a tough process to replace it - for a 97 Camry?
Thanks
Apr 20, 2008 at 5:17 PM
  • 31,937 POSTS
Hi there,
This is not a hard job to do, you will have to remove the exhaust engine pipe and the lower cross member, the engine will hang on th remaining mounts ok. The sump should be chemically sealed (no gasket ) this will be the tricky bit, breaking the seal, there is a special tool available for this task. make sure you clean all the old sealant of the mating surface and use only Toyota sealant ask for the sump sealant (i think it is black in colour) apply exactly as the instructions recommend and you will have no problems.
mark (mhpautos)
Apr 21, 2008 at 5:49 AM
