1994 Toyota Camry
HARRYKEITH
  • 1994 TOYOTA CAMRY
Engine Mechanical problem
1994 Toyota Camry 6 cyl Front Wheel Drive Automatic
I HAVE AN OIL LEAK THAT I CAN'T FIND. I AM USING A FRAM PH3614 OIL FILTER WHICH IS THE FILTER ACCORDING TO FRAM. THE LEAK IS A SLOW DRIP THAT COMES FROM SOMEWHERE NEAR THE FILTER AND THEN DRIPS DOWN TO THE OIL PAN. I HAVE TIGHTENED THE OIL PAN BOLTS AND I AM AT A LOSS.
HARRY
Wednesday, January 7th, 2009 AT 11:00 PM
  • 31,937 POSTS
HI there,
You will have to wash it down and check the leak after a short engine run, don't take to long as it will be harder to trace back the leak, but I would be checking the filter seal and the oil pressure switch and the rocker covers first.
Mark (mhpautos)
Thursday, January 8th, 2009 AT 12:17 AM
