1995 Toyota Camry oil pan gasket
JAIDYN588
  • 1995 TOYOTA CAMRY
  • 6 CYL
  • 177,000 MILES
Oil pan gasket leakage
Monday, December 1st, 2008 AT 1:48 PM
  • 31,937 POSTS
HI there,
This is not a difficult job to do, with the car on work stands, drain oil remove exhaust engine pipe, & engine cross member, engine will hang on two mounts safely, undo all sump bolts and remove sump. Now these are a chemically sealed sump and can be a bit hard to shift, you have to clean all the sealant off sump & block, use only Toyota sealant follow instructions in package exactly and you will not have a problem.
Mark (mhpautos)
Monday, December 1st, 2008 AT 3:02 PM
