1997 Toyota Camry Loses Coolant With Heat
MIKE WEBBER
My 1997 Camry loses coolant when the heater is used, but there is no sweet smell inside the passenger cabin. It does not lose coolant when the heater is not used. Is this a heater hose problem?
Nov 8, 2006 at 11:26 PM
BACKYARDMECHANIC
  • 337 POSTS
Dear Mike
Try and take a look under the hood on the passenger side against the firewall. There should be two hoses feeding into the heater core. There should also be a value which is operated when you turn on the heat. With the car running and at operating temperature have a assistant turn the heat on while you check for leaks at the above locations mentioned.
Goodluck :) Backyardmech
Nov 8, 2006 at 11:49 PM
MIKE WEBBER
[quote:c85331182a="backyardmechanic"]Dear Mike
Goodluck :) Backyardmech[/quote:c85331182a]
Hey, thanks alot
Mike :D
Nov 9, 2006 at 12:10 AM
Suggested Repair
With the engine at operating temperature, have an assistant turn the heat on while you inspect the two heater hoses and the heater control valve at the passenger-side firewall for leaks.
Conversation Summary
The owner reports a 1997 Toyota Camry loses coolant only when the heater is used, with no sweet smell in the cabin, and asks if a heater hose is at fault. The expert advises checking the heater hoses and heat-operated valve at the firewall for leaks while the engine is warm and the heat is switched on. The owner thanked the expert.
