1995 Toyota Camry Coolant Leak
ZCMZCM
I found overheating two weeks ago when I was driving.Then I pulled over and check coolant. Found there was no coolant in reserve tank. So, I added some coolant. After 3 hous, I checked again, And There was nothing left again. So, I add more coolant, and made a mark. Now, about 2 weeks after, the level decreased about 4 cm. I check the ground, there was nothing. and there is no white smoke from tailtube. Is there anyone can help me out?
Sep 16, 2007 at 3:13 PM
  • 31,937 POSTS
Hi there,
You will have to have the cooling system pressure tested with the engine warm, this will show up any small leak that might otherwise go unnoticed, small leaks can be very hard to locate as there are hoses that are very hard to see at the best of times. Also have the pressure cap (radiator cap) tested, as these are often overlooked.
mark (mhpautos)
Sep 17, 2007 at 10:34 AM
Suggested Repair
Pressure-test the cooling system with the engine warm to locate small or hard-to-see leaks, and test the radiator pressure cap, which is often overlooked.
Conversation Summary
The owner of a 1995 Toyota Camry reported overheating and repeated coolant loss from the reserve tank, with no puddle on the ground and no white smoke from the exhaust. The expert advised a warm-engine cooling-system pressure test to reveal small leaks and a separate test of the radiator cap.
