1996 Toyota Camry High NOX at 15mph, good at 25mph - please
J_GEE
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 130,000 MILES
My car failed the CA smog check. The following are the results:
15mph: %CO2 = 14.7; %02 = 0.3; HC (ppm) = 14; %CO = 0.00; NO (ppm) = 1297
25mph: %CO2 = 14.9; %02 = 0.0; HC (ppm) = 8; %CO = 0.02; NO (ppm) = 84
I checked EGR by applying vacuum at idle => stalls car.
What can cause bad NOX at 15mph, but fine at 25 mph? All other measurements are fine. Please help!
Monday, October 18th, 2010 AT 10:38 PM
Hi j_gee, Welcome to 2carpros and TY for the donation
High Nox-normally is caused by an EGR valve problem-clean it out, also the catalytic converter or a parameter sensor staying in open loop mode-let me know
Tuesday, October 19th, 2010 AT 12:20 AM
