HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Interior
Dashboard
Light
SPONSORED LINKS
1996 Toyota Camry dashboard lights
DIANETURK
MEMBER
1996 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
140,000 MILES
I have no working dashboard lights, how difficult is it to fix?
Thursday, May 27th, 2010 AT 7:58 PM
BLUELIGHTNIN6
MECHANIC
You mean instrument cluster along with radio has no lighting? Could be a fuse and is easiest to check.
SPONSORED LINKS
Saturday, May 29th, 2010 AT 8:47 PM
DIANETURK
MEMBER
Just the lights for the instruments (speedometer, RPM, gas guage). The radio lights are fine
Saturday, May 29th, 2010 AT 9:21 PM
BLUELIGHTNIN6
MECHANIC
Check fuse #10 (15 amp) in the fuse panel, if it's OK then most likely the bulb is at fault.
Saturday, May 29th, 2010 AT 9:27 PM
Please
login
or
register
to post a reply.
Related Dashboard Light Content
Dashboard Lights
Interior Problem 4 Cyl Front Wheel Drive Automatic 80,000 Miles There Are 3 Dials On The Dash That Work The Fan, The Ac/heat Selection...
Asked by
jsaya
11 IMAGES
2003
TOYOTA CAMRY
Light Failure Dash Light
All The Lights In The Car Work Fine, But The Dashboard Light Failure Indicator Light (picture Of A Car With "lights" Written Under It)...
Asked by
Nolin
1988
TOYOTA CAMRY
1987 Toyota Camry Rear Tail Lights And Dash Board...
Help My Dashboard Lights Stopped Working Smelled Funny And As I Was Going Home At Night A Policeman Pulled Me Over As My Tail Lights Dont...
Asked by
kb00b00bear
1 ANSWER
1987
TOYOTA CAMRY
1993 Toyota Camry Dash Lights.
Whenever My Car Is In "drive" The D On The Dash Does Not Lite Up And When I Press On The Brake The R Lites Up. The Light Warning Icon (...
Asked by
fhumble
1 ANSWER
1993
TOYOTA CAMRY
1991 Toyota Camry Dash Lights
Intermittently, Dash Lights -- Brake, Oil, Check Engine, Lights, Battery, Oil -- Will Come On, Go Off, Flicker, When Hit A Bump In...
Asked by
RichardMelody
1 ANSWER
1991
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Instrument Cluster Replacement
Airbag Removal - Drivers Side
Hood Open
Online car repair manuals
