Hi fhumble,
Thank you for the donation.
The D light not indicating could be due to a blown bulb or a fault with the Park Neutral Position switch. You would ahve to remove the meter cluster to test or replace the bulb.
When the R indicator light comes on while braking, it is usually caused by a abd ground circuit at the rear taillights. Check the taillight gound circuits. Remove, clean, retighten and retest.
SPONSORED LINKS
Thursday, September 2nd, 2010 AT 9:30 AM
