Brakes problem
1993 Toyota Camry 4 cyl Two Wheel Drive Automatic 237, oo miles
how do I reset the dashboard lite for the breaks so it will go off, both the abs light and the break lite
Sunday, March 14th, 2010 AT 11:01 AM
LEGITIMATE007
MECHANIC
Did you fix the problems associated with the lights? Did you scan it?
SPONSORED LINKS
Sunday, March 14th, 2010 AT 11:15 AM
LEGITIMATE007
MECHANIC
To shut the lights off, you need to put it on a scantool and erase the codes, but if the repair hasnt been done for whatever reason the codes are there in the first place, they will come right back
