Light failure dash light
110,000 MILES • 3.4L • 4 CYL • 2WD • AUTOMATIC
NOLIN
All the lights in the car work fine, but the dashboard light failure indicator light (picture of a car with "lights" written under it) stays on while the car is running. After ignition, idling in park, it is not on. As soon as I step on the brake, it comes on and stays on. I also tried starting the car in neutral (light not on) and sliding the shifter into drive without touching the brake pedal. Again, the dash light comes on and stays on. Could this be a brake switch problem, or some wiring issue? Any help would be welcome. Thanks
Jun 23, 2016 at 10:00 AM
  • 110,248 POSTS
Have you confirmed that all exterior lights are working?
Jun 23, 2016 at 11:51 AM
NOLIN
Yes, all exterior lights are working.
Jun 23, 2016 at 12:03 PM
  • 110,248 POSTS
If they are all working, something tells me you have a short to power which is providing power to that light. Check under the dash for anything that appears damaged, rubbed bare, or pinched.
Jun 23, 2016 at 12:11 PM
NOLIN
Ok will do - thanks for your help.. hope it's something simple as a pinched wire..
Jun 23, 2016 at 12:41 PM
  • 110,248 POSTS
Good luck
Jun 23, 2016 at 2:11 PM
