1991 Toyota Camry DASH LIGHTS
RICHARDMELODY
  • 1991 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 75,000 MILES
Intermittently, dash lights -- brake, oil, check engine, lights, battery, oil -- will come on, go off, flicker, when hit a bump in the road they will be effected. Won't pass inspection with check engine light on. But it seems to be electrical, not emissions.
Sunday, June 28th, 2009 AT 10:38 AM
KHLOW2008
  • 41,814 POSTS
Hi RichardMelody,
Thank you for the donation.
There could be 2 issues here.
1. CEL showing because there is a fault in the engine management system. Get a scan done and let me know the exact trouble code. You can get it scanned at Autozone, they provide the services free.
2. Dash lights flickering could be due to a loose wire connection somewhere and most probably it is at the meter cluster connectors.
You would need to remove the meter cluster to check.
Sunday, June 28th, 2009 AT 12:40 PM
