1994 Toyota Camry shifting on the hwy
TROY STOUT
  • 1994 TOYOTA CAMRY
1994 Toyota Camry
when the car is cold it wont shift into the last gear until the car warms up then its fine. It is an automatic
Thursday, April 24th, 2008 AT 12:01 AM
  • 31,937 POSTS
Hi there,
The first thing to do is get the transmission serviced and see hoe it changes, if still causing you a problem, you will have to get the line pressures tested, you may have sticky shift valves in the transmission valve body.
Mark (mhpautos)
Thursday, April 24th, 2008 AT 5:36 AM
