1994 Toyota Camry
KBAMH
  • 1994 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 178,000 MILES
This started about 3 years ago and I have been too cheap to take the care somewhere. The car started to not shift out of first gear unless I released the gas. Now I have to do that for every gear. I'm pretty sure this is a electrical problem because it has been going on so long and the transmission has not went out. What do you think?
Wednesday, September 30th, 2009 AT 9:05 PM
  • 31,937 POSTS
You need to get the transmission tested you a qualified transmission repairer, this could be a pressure related issue, you should never let these problem go unattended as you may end up with a bigger repair bill in the long term.
Mark (mhpautos)
Thursday, October 1st, 2009 AT 12:02 AM
