1994 Toyota Camry
190,000 MILES • 4 CYL • FWD • AUTOMATIC
HROGMB
When I get out of my car, and sometimes when I am still in the car I can smell gas. I have notice that my gas in the gas tank does not last very long. The car was checked for checked for leaks and did not find any.
Nov 19, 2009 at 2:03 AM
  • 75,988 POSTS
Hi hrogmb and TY for the donation
Check the charcoal canister if its saturated with fuel/gas cap and the Evap hoses leaking -if not could be just running to rich caused by the following:
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Nov 19, 2009 at 2:16 AM
