Someone poured boric acid in my gas tank. It caused fuel pump to fail. The area where you insert the nozzle to add gas is badly corroded. How do I fix this problem? The fuel gauge is not working and fuel pump failed and blew fuse in one or two minutes after starting car. Already replaced fuel pump. What do I do next?
Oct 8, 2016 at 11:18 AM
