1994 Toyota Camry Timing Belt Broke
[quote:d86bdaf81a="harperl"]I have a 1994 Toyota Camry 4 cylinder 210,000 miles- water pump burst, timing belt broke- could valves be bent? ball park cost to repair? shame- super car.[/quote:d86bdaf81a]
8 out of 10 you are ok
$$350 to $500
change the pully and the water pump
i think they have a kit
t belt w pump pully
$$350 to $500
t belt w pump pully
Sep 19, 2007 at 12:19 PM
20 to 30 min job if you know what your doing, replace the belts too. if it needs the outside belts it needs a t-belt, and no on the kit everything ala-cart
Sep 21, 2007 at 4:09 PM
Suggested Repair
Replace the timing belt, water pump, and pulley, and replace accessory belts if they are due. One expert estimated about $350 to $500 and said valves are likely undamaged in most cases; parts may be bought as a kit or separately.
Conversation Summary
The owner of a 1994 Toyota Camry 4-cylinder with 210,000 miles asked whether a burst water pump and broken timing belt could bend valves and what repair might cost. One expert said valves are likely fine in about 8 of 10 cases, estimated $350 to $500, and recommended replacing the timing belt, water pump, and pulley, noting a kit may be available. Another expert said an experienced person can do the job quickly, advised replacing the belts as well, and preferred buying parts separately rather than as a kit.
