1994 Camry cooling system issue
1994 TOYOTA CAMRY
KATFINN
1994 Toyota Camry, radiator blew, after replacing, the fan no longer works unless the heat or the A/C is on. Help?
Sep 14, 2007 at 9:29 AM
[quote:289034d8c2="katfinn"]1994 Toyota Camry, radiator blew, after replacing, the fan no longer works unless the heat or the A/C is on. Help?[/quote:289034d8c2]
Welcome to 2carpros
For a start did you change the thermostat? Try checking the coolant temperature sensor it tells the computer to energize the relay so the fan will come On and also a temperature switch. Or could be the cooling fan motor defective-check all connections-
Check for power at the fan motor when the engine is fully warm up-also did you bleed the cooling system.
Sep 14, 2007 at 9:38 AM
