1993 Toyota Camry Black tranny fluid
1993 TOYOTA CAMRY
110,000 MILES • 6 CYL • FWD • AUTOMATIC
DARLA
I brought my car to a mechanic because it sometimes stalls at stoplights/signs. (Never did resolve that issue either). While he had it idling waiting for it to die, he was checking the fluids and found the tranny fluid was black. He says it means the tranny is bad or will go soon but I've never had a problem with it. Is this common? Is it worth it to flush and keep driving? Any thoughts/comments would be helpful on either subject.
Jun 11, 2008 at 10:58 AM
  • 31,937 POSTS
Hi there,
The transmission is well over due for a service, hopefully if you have not had a problem with it, a flush &b a service will be all you need. As for the stall, a scan check first looking foe TPI problem, check idle, all tune items Start there.
Mark (mhpautos)
Jun 11, 2008 at 11:18 AM
